Re: Farmall 560 Starter Keeps Running
Posted by El Toro on February 06, 2005 at 04:21:05 from (152.163.101.13):
In Reply to: Farmall 560 Starter Keeps Running posted by Old_Farmall_560 on February 05, 2005 at 13:52:49:
I think you're still having voltage applied to the starter solenoid after you release the starter switch. There's voltage at the starter all of the time. Try shorting across the solenoid with a screwdriver to start the engine with the ignition switch off. If it keeps cranking your solenoid is bad. If it stops cranking, voltage is being applied to the solenoid
probably from a defective push button. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
