Re: 4166 steering
Posted by redfarmer on February 08, 2005 at 19:29:24 from (207.69.136.198):
In Reply to: Re: 4166 steering posted by P Backus on February 08, 2005 at 18:46:19:
My thought with the plumbing change was that it might make the circuit more prioritised to the steering valve than the brakes sinced two other guys had responded and were pretty certain the problem had came from lack of hydraulic pressure.As I look back signs of the pressure problem started last summer when I was barely able to fold the wings up on a 28' field cultivator.Then I used a backhoe on it and things just got steadily worse.I don't know if you have a three point but I do so my pump is the 30 gallon pump which operates the rear steering and brakes on a built in priority circuit,the remaining flow is given to the hitch and auxiliary circuits.The front steering is supplied by the 9 gallon pump which also supplies the transmission lube circuit and oil cooler.You mentioned your implements settle too quickly,if you mean they just gradually go down I would suspect worn spools.Since hydraulic valves use only a tight spool to bore clearance to seal the oil there isn't anything you can do to the valve once it is worn. You could however add a check valve to the circuit after the valve,this would hold the implement in any position until pressure was applied in either direction.Hope this helps.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
