Re: farmall m hydralic pump removal
Posted by Haas on February 09, 2005 at 17:37:59 from (12.65.19.145):
In Reply to: farmall m hydralic pump removal posted by tim bynum on February 09, 2005 at 17:23:44:
Comes out the bottom. You must unscrew all the elbows (three of them) that are the connections for hydraulic implements. These go through holes in the sides of the torque tube (clutch housing). Also must disconnect the operating lever. It is attched to the operating control shaft with a screw. Now the coupling that drives the pump must be rotated so the cross is vertical and it will slide out of the slot that it runs in. Then you can drop the pump out. CAUTION!! It's very heavy and you need help, or some tools. You can replace each of the 3/8 bolts that hold it in one at a time with threaded rod with nuts on the rod and then screw the nuts down the rods to lower the pump. Somewhat time consuming but safe if you make sure not to unscrew the rods out of the clutch housing. Also special tools available (Tee Handles) that fit in the horizontal hole at bottom of the unit. If you have those, you can put cribbing or a jack under them to lower the unit.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
