Re: 1949 H starter
Posted by captaink on February 10, 2005 at 09:58:13 from (66.115.214.56):
In Reply to: 1949 H starter posted by Ronald Jones on February 07, 2005 at 23:01:57:
I have to throw in my 2 cents. A 6-volt starter will hold up just fine. I have an M that was converted 20 years ago. It usually sits outside in the cold in winter (down to -25 F some winters). I replaced the starter once in that time, and it was my everyday loader tractor. I don’t baby the starter, nor do I abuse it, actually I think 12 volts is easier on it than a poor 6-volt system. Here’s why I think this way: There is an equation in electricity that states: watts (electrical power) = volts (push) X amps (current flow) For example if you have a 700 Cold Cranking Amp 6-volt battery and 100% of it goes to the starter you will get 4200 watts of electrical power. (Remember how hot your 1500 watt toaster gets) Now, to achieve 4200 watts of electrical power with 12 volts, you only need 350 amps. The lower current flow makes the 12-volt system more forgiving on poor connections etc. Your H will take a certain amount of power (watts) to turn over (depending on temperature) regardless of 6 or 12 volts, so the actual power consumption of the starter will be the same. If you follow good starting practices (10 seconds run, 1 minute rest) you won’t hurt that 6-volt starter. The jaming mentioned in another post is not because of 12 volts, it is either a bad ring or bendix gear.
Home
| Forums
Today's Featured Article -
Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
