Re: Can not keep Super A running
Posted by El Toro on February 10, 2005 at 17:36:19 from (205.188.117.13):
In Reply to: Can not keep Super A running posted by Cris on February 10, 2005 at 16:43:10:
Hi Cris, Pull a plug wire off and look for a good spark. Have someone crank over the engine
after it quits while you hold that plug wire near the sparkplug and see if you have a good hot spark. If you still have good spark while cranking then I think you have a fuel problem.
If the spark is weak or no spark, then go down to the next paragraph.
Replace the condenser and then start
engine and see if it keeps running and if it does that was the problem. If it quits running replace the coil. Is this battery ignition on the tractor or does it have a magneto?
Make sure you're getting gas to the carburetor by
loosening the tube fitting at the carb. Hal
Does this tractor have a ballast resistor?
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
