Re: Paint stripper
Posted by Gordo on February 13, 2005 at 08:01:19 from (64.68.166.234):
In Reply to: Paint stripper posted by r4etired on February 11, 2005 at 18:13:53:
What kind of primer did you use? Did you use a metal prep solution? The BEST modern approach to old bare metal is acid etch primer. Then withinn 48 hours a paint primer, or primer surfacer if you are going to "WORK" Steel items. On cast you still need the two primers.Doesn't matter if you sanded, stripped, or blasted them. The Nason etch primer is about 35 dollars for a quart of primer and a quart of conditioner (acid mixture).
Gordo-SD
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
