Re: adding live hydraulics to Farmall H
Posted by Theman on February 14, 2005 at 13:24:08 from (65.248.77.5):
In Reply to: adding live hydraulics to Farmall H posted by zooeyhall on February 14, 2005 at 11:42:44:
1) If you plan to put a suction line strainer between the Liftall housing and the pump, you don't need the nipple to trap debris in the sump. You want it going to the filter to be eventually eliminated at filter change time. Besides, you're only letting sediment rob you of precious capacity. 2) Sounds good. 3) You didn't mention the type or capacity of your live pump. You would do well to use an open centered valve so you have constant flow and minimal heat buildup. It should have a built-in pressure relief valve and should be set to protect your pump. If you get a closed centered valve, your relief valve will operate constantly when not raising or lowering your implements, putting a major strain on the entire system. 4) Yes, you can leave the liftall intact but it sort of defeats the purpose of adding a live pump. I recommend gutting the housing and making a plate and gasket to cover the opening. It will give more capacity to your system. 5) A suction filter is recommended to extend the life of your pump. Replaceable element (spin-on) filters are preferred over the screen type.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
