Re: 1468 wheatland?
Posted by Red Rider on February 17, 2005 at 21:19:48 from (66.235.45.149):
In Reply to: 1468 wheatland? posted by 1468 farmer on February 17, 2005 at 15:29:18:
IH did not offer the 1466 or 1468 in a Wheatland model. On previous Wheatland models (International) the wide front was not adjustable and set back under the front further than the Farmall models. The Power Steering cylinder was mounted paralell and just under the right hand front frame were as the Farmall power steering cylinder mounted under the front and actually to the wide front stay rod bracket. Now there was an option for high coverage fenders like the wheatland tractors used. There were three draw bars available for l466/68 tractors. One came with the tractor when equiped with a 3 point. Tractors without a drawbar had one that bolted directly to the rear of the tractor and the other attached to the rear axle via drop down brackets and had stablizers that attached to the drawbar and up to the sides of the rearend housing.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
