Farmall Tractors Discussion Board
Cub frame support
Posted by p on December 01, 1999 at 12:49:27 from (209.186.155.152):
I have two Cubs and both have a stress crack in the frame(block) in the drivers side where it attaches to the front end. (behind the water line) I have learned that this is a common problem for machines used on rough terrain. I also heard that the International series used a brace to strengthen this weak point. I have welded and made my own brace for the '52 but I want to fix the 49 to use it again, and I don't want to rip it apart to have it welded (this is the reason it was put in the barn...). Does anyone know where to get the brace, or where it bolted from so as to compare it to the one I made before. I went from where the motor and front end meet, to the clucth attachment point with 1/8 inch short to snug it up. seems to work but.....
Post A Followup
: Re: Cub frame support
