Re: h govenor
Posted by Bob M on February 18, 2005 at 11:19:13 from (151.190.254.106):
In Reply to: h govenor posted by RandyNark on February 18, 2005 at 09:55:23:
Randy - The advice below is right on. But before you start tearing the governor apart, check to see that the carb throttle plate is opening all the way. (If it does not your motor will lack power exactly like you describe.)
Take a small inspection mirror and slide it into the carb air inlet so you can see up thru the carb venturi. Then shine a flashlight onto the mirror so it illuminates and you can see the throttle plate.
With the engine stopped and the governor handle pulled all the way back, the plate should be full open (straight up and down). If it is not, take the cover off the governor riser (the sloped cover with the vent tube attached) and adjust the bellcrank underneath until the throttle plate opens all the way.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
