h govenor
Posted by RandyNark on February 18, 2005 at 09:55:23 from (66.82.9.84):
Hi guys I asked this question the other day but forgot the rest of info you need here goes.
I have a forty-one H a good running tractor but the problem is at full throttle in runs good but as load is applied it does not rev any higher and will bogg down. For example pulling a brush hog and going along fine and hit a thick spot of burmuda and govenor does not open up and tractor will bog down until you stop. Is there an adjustment on the govenor to make it respond to demand for revs. Thanks in advance.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
