Re: Piston rod bearings on a Farmall A C113 engine
Posted by ddg on February 19, 2005 at 06:55:36 from (205.188.117.13):
In Reply to: Piston rod bearings on a Farmall A C113 engine posted by MACE on February 18, 2005 at 19:17:53:
While the pan"s off, you ought to take one of your main bearing caps off & look at those too. I was into my early "48 SA last month, and found the original mains stamped "Std. 8-47" They were standard size. The journals looked good, and I couldn"t eyeball or feel any slop, so I put new Std. inserts back in. The originals had very little if any wear. Carrying good oil pressure so close enough I guess. My rod bearings were std"s also with very little wear, & replaced with same. Runs smooth & quiet.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
