Re: Piston rod bearings on a Farmall A C113 engine
Posted by Opa A on February 19, 2005 at 18:19:09 from (161.184.54.153):
In Reply to: Piston rod bearings on a Farmall A C113 engine posted by MACE on February 18, 2005 at 19:17:53:
You're on the right track. All the comments below are also good advise. Your crankshaft should also be stamped with the undersize that the machine shop ground it to. If it has been running with .030 under bearings and they look as good as you say, then you will have no problem reinstalling .030 under bearings. Plastigage them as you are reassembling. Part numbers for main bearing set is 575M-30 in Federal-Mogul or MS2459P-30 in TRW. Part number for rod bearings are 1795CP-30 in Federal-Mogul or CB386P-30. The -30 in the part numbers indicates .030" under standard size.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
