Re: IHC vs. JD
Posted by bill koob on February 20, 2005 at 06:00:12 from (69.9.216.26):
In Reply to: Re: IHC vs. JD posted by supermpuller on February 19, 2005 at 11:12:48:
I do not have the tests but it is not rocket science the tractor with the most weight..best tires on the rear end ... highest drawbar will always pull the most in a low gear...with similar hp.. Who pulled the most at 3.5 miles per hour, where the maximum slippage allowed 15% was not a factor (limitation)....Not to worry superMpuller there is an explanation even if you do not want to see it.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
