Re: drawbars on letter series
Posted by williamf on February 21, 2005 at 15:59:52 from (66.82.9.75):
In Reply to: drawbars on letter series posted by Shepherd_Bill on February 21, 2005 at 12:42:12:
third party image
After a generation or so wear starts to show.
On my '46 H, which is older even than I, the top layer of drawbar has a pretty noticable dip in the center, right where the roller of the swinging drawbar rides. A previous owner welded a second drawbar the whole way around for reinforcement. Since I use it mostly for pulling a fairly heavy single axle dump tailer I hung the roller on the wall and did a little more build up. The swinging bar doesn't swing now, put it still slides front to back.
I had to have the swinging bar staightened and a piece welded to the bottom of it, too. And the holes at each end built up.
Wm
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
