Re: m and super m carberator the same?
Posted by CNKS on February 21, 2005 at 18:28:45 from (204.249.178.138):
In Reply to: m and super m carberator the same? posted by Kevin Farmall on February 21, 2005 at 18:13:42:
They may appear to be the same, but the jets are different. If the Super M carb (I don't have one) is adjusted the same as the Super H, max power is obtained with the main jet screw 5 turns out, as opposed to the M which is 1/2 turn or so open after it runs smooth. I would guess the bowls are the same, but you will need the Super M jet. Someone with both parts catalogs needs to compare the numbers to be sure. On the other hand, why don't you just replace the jet (if you can get it out)
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
