Re: My First H - Problems
Posted by Bob M on February 22, 2005 at 07:06:48 from (151.190.254.108):
In Reply to: My First H - Problems posted by colekicker on February 21, 2005 at 23:06:43:
“It will not shift into any gear, but it won't shift out either. I have raise one tire to get it to turn, and it still won't move. Did the same to the other side and no luck.”
These are the classic symptoms of a worn shift lever causing the transmission to get caught in two gears at once.
First thing I’d do is remove the shift lever (knock out the cross pin where the lever enters the tranny cover) and peek inside. If the slots in all 3 shift rails are not centered in the opening, take big honkin’ screwdriver or similar and use it to move the rails so all 3 slots are centered. It may help to jack up one rear wheel if the rails are hard to move.
Otherwise the advice below is right on. Good luck!!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
