Re: H throttle shaft
Posted by Theman on February 23, 2005 at 08:57:11 from (65.248.77.5):
In Reply to: H throttle shaft posted by haymeadow52 on February 22, 2005 at 19:00:23:
I had the same problem on my '47 H. I built it up with brazing rod then carefully ground it back to fit the slot on the carb shaft. Since the slot on the new throttle shafts is now a plastic piece, it will take many years to wear the brass down. Corrosion is less likely too, which was the original cause in my case.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
