Re: new 6V battery and charging system
Posted by Doug in OR on February 23, 2005 at 20:45:49 from (24.20.250.197):
In Reply to: new 6V battery and charging system posted by riverbend on February 23, 2005 at 06:39:21:
Those are darned good, but expensive batteries. I put one in my car last weekend. It says to never go above 15 volts for the 12 volt version - so your 7.5 volt maximum sounds about right. You really want to keep your charging voltage around 7 to 7.1 volts anyway. All batteries will last longer this way. You can adjust the third brush, as others have said, or you can look for a bigger resistor for your field winding. You can also look for a 6 volt alternator, which would be the perfect solution.
Check out the Peukert Number on those spiral wound batteries. They have the lowest (best) number of any I"ve seen.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
