Re: Farmall 200 6 to 12volt
Posted by Dave_Id on February 24, 2005 at 09:20:08 from (66.82.9.16):
In Reply to: Farmall 200 6 to 12volt posted by jms/Farmall 200 on February 24, 2005 at 07:48:11:
You can buy a single wire Delco Alternator at Napa, but are you sure these problems won't continue? Maybe you just need fresh wiring, and heavy battery cables that are neccesary for a 6 volt system. Your 6 volt starter will run off 12 volt, you will need to switch to 12 volt bulbs, and reverse the wires on amp gauge if you go to negative ground.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
