Re: 10-20 engine freed, piston/sleeve question
Posted by El Toro on February 27, 2005 at 03:37:13 from (205.188.117.13):
In Reply to: 10-20 engine freed, piston/sleeve question posted by Greg (TX) on February 26, 2005 at 16:34:04:
Hi Greg, I would keep pouring transmission fluid
into those cylinders to see if the pistons will
free up. Since you can move the pistons slightly
I would keep trying to rotate the engine. We had a 10-20 when I was a kid. It was bought before I was born in 1926. It replaced a Fordson that my
late dad couldn't never get started and they kicked like a mule. They had a problem of flipping backwards too. You could probably drive
out those pistons, but it may be difficult to do that if the crankshaft is in the wrong position.
I drove them out of Farmall A that was seized and the sleeve and piston came out together on two
and the other two pistons came out without the sleeves. I pulled the engine off so I could
work on it easily. Those 10-20's were very good tractors and were easy to start. In 1950 we got an H Farmall. I think they sold that 10-20 for $200.00. They should've kept it. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
