Re: 10-20 engine freed, piston/sleeve question
Posted by El Toro on February 27, 2005 at 11:02:53 from (205.188.117.13):
In Reply to: 10-20 engine freed, piston/sleeve question posted by Greg (TX) on February 26, 2005 at 16:34:04:
Hi Greg, Since it posted the last message I'll retype this again. If one of those connecting rods is turned downward where you can remove the cap I would try tapping it out with a piece of wood to see if it moves any. Those rods have shims and you should be careful to remove these and reinstall on the rod after you get the piston out. Those rod caps should be numbered and should face the camshaft side of the engine. These rods have dippers too since the engines back then didn't have oil pumps. Your sleeve may come out with piston, so do not get worried. If it does you can heat those sleeves with a torch, so you canremove the piston. You are probably going to use the old rods. Are you going to pull the engine? That crankshaft is probably egg-shaped due to the oil system they used back then. It probably will need machining too. Federal Mogul at one time would rebabbit your old rods like new. They needed the dimensions of the rod journals too. I had the redo some rods off a garden tractor known as the Standard Twin and Viking Twin. I restored 6 of these. These tractors were away ahead of their time since they were all gear driven and had a pto. I still have a moldboard plow off one of them that I adapted to my garden tractor. I've had that plow since 1960. I changed the point once. Hal
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
