Re: 300 utility ta???
Posted by PAULIH300 on March 01, 2005 at 14:25:12 from (152.163.101.13):
In Reply to: 300 utility ta??? posted by Amishbob on March 01, 2005 at 11:01:50:
The TA was optional.Not all had it.Check your serial number as its coded into that.Also,you would have TA emblems on either side of the dashboard.A TA merely lowers the gear ratio,sorta like a granny gear in each gear...or a LOT like Mitsubishi's old "Twin Stick" with a normal AND performance ratio in each gear.That was found in Dodge Colts and Champs back in the early 80s.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
