454 help needed
Posted by ljw on April 05, 2009 at 08:22:38 from (66.191.76.174):
I bought a 454 gas utility that seamed to need a carb cleaning. It stumbles when I increase the throttle rapidly or when the governor is activated. I have installed a new carb kit, cleaned it thoroughly, several times, but no change in performance. I replaced the intake/exhaust manifold gasket, spark plugs, points, wires, checked the compression (150 on all), set the timing and even slightly advanced the timing and still no change in performance. It starts fine, runs well, has good power but still falls on it"s face when you throttle up quickly or when the governor kicks in. I don"t know where to go from here. Any suggestions?
