Posted by JimB2 on April 05, 2009 at 08:56:14 from (99.240.236.11):
In Reply to: 454 help needed posted by ljw on April 05, 2009 at 08:22:38:
Hi, my first disclaimer, I have never worked on gas model of 454 only Diesel model but the usual cause of the stumbling when throttle is advanced rapidly is to lean of gas/air mixture. One of the causes was vacuum leaks and since you have replaced the manifold gasket it s probably not a vacuum leak. Another was the low speed/idle jet being adjusted to lean. I looked at caseih.com parts for C-152 gas engine carb and did see an idle adjust screw for carb, so try openning idle adjust screw an 1/8 of a turn at a time and see if this helps any.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
