Re: Yup
Posted by PAULIH300 on March 03, 2005 at 19:21:05 from (205.188.117.13):
In Reply to: Re: Yup posted by iester on March 03, 2005 at 19:11:37:
The battery is in a marine battery box.I also have a master disconnect on the negative side inside the box.When I first saw a battery sitting between where my legs would go I freaked out.No way I was going to sit behind a battery that could spill acid/explode uncontained.The battery box also keeps the post from accidentally shorting against the dash.I run rubber post covers even though its inside the box.
The battery is a NASCAR Select,and cranks with authority even when below zero.I have reapplied the shift diagram and warning decals atop the box cover.
  • Re: Yup iester 19:34:21 03/03/05 (1)
  • Re: Yup Sloroll 19:25:14 03/03/05 (3)
    • Re: Yup iester 19:40:19 03/03/05 (0)
    • Re: Yup PAULIH300 19:35:41 03/03/05 (1)
      • Re: Yup iester 20:22:53 03/03/05 (0)
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
