Please Help///Re: engine dies when mower engaged
Posted by Cobrajet on April 05, 2009 at 08:26:01 from (74.131.78.132):
In Reply to: engine dies when mower engaged posted by Cobrajet on April 03, 2009 at 16:48:43:
hello all! i tried all suggestions today with no luck..
No vacum leaks around carb or intake. installed new gaskets anyway.
opened carb up again re-did all internall parts again.
pulled all plugs re-gapped .025
points re-gapped .020
firing order 1-3-4-2
button does turn clock wise if that helps?
tank drained "clean no rust"
fuel bowl clean.
new screan.
gas line free and clear.
filter at end inside of carb free and clean.
when gas line off gas runs freely.
when on carb and bolt removed runs freely.
also tried to rotate distributor minimal change.
im at a lose!!!! Im sure it will be somthing very simple that i've missed.
All parts are new. cap/rotor button/plugs/wires/points
