Re: Frozen Steering on Farmall 856
Posted by Chuck's Repair on March 07, 2005 at 17:26:17 from (216.170.58.10):
In Reply to: Frozen Steering on Farmall 856 posted by PJ@Ohio on March 07, 2005 at 06:50:47:
I had the same problem once.There was water accumulated in the steering cylinder that didn't reserculate back to the sump.Every time the temperature droped below freezing the cylinder would freeze up.This can be easilly checked by teeing a hydraulic gauge in one of the steering lines and leting it set outside over nite.If the pressure climbs to 2200 PSI when you turn the steering wheel and the front wheels don't turn you know there is a block of ice in the cylinder or steering gear.To fix you will have to remove the radiator and remove the top cover on the front bolester and remove the large nut on the steering gear and lower it out the bottom to remove the water.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
