Re: Regular side draft carb
Posted by Kevin (LA-CA) on March 07, 2005 at 17:35:27 from (199.46.200.234):
In Reply to: Re: Regular side draft carb posted by Sloroll on March 07, 2005 at 07:15:56:
I struggled with the carb on my 1928, but it works pretty well now. It has been 4 years since I have had to work on mine. I am working from memory, so forgive me if the following isn't completely correct. Remove the air cleaner connection - see if the gas is running out the intake. At least this will prevent the crankcase from filling. I am surprised that gas isn't dripping from some of the carb vents on the backside near the needle. How is the gasket/fit between the mixing float bowl and the stem/nut that holds the cover on. If this leaks, the bowl will never fill enough to float. Is there a pin hole in the bottom or the neck? Also try assembling the bowl and top (with stem nut), but not the mixing chamber. Apply fuel. See if / where it leaks. Are you assembling the bowl with carb upside down? This makes sure the float is positioned, and cannot be caught on the bowl. Is the float centered in the bowl? I bent arm on the float so it was a little less than level - i.e. float in full up position angles downward from the needle end. Try to starve it. But, it sounds like you have adjusted this though.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
