Re: Alternator Wiring Question.
Posted by captaink on March 08, 2005 at 09:53:37 from (66.115.214.56):
In Reply to: Re: Alternator Wiring Question. posted by Doug in OR on March 08, 2005 at 09:19:39:
Yup, I even run the exciter line from the swith without a lamp or diode. I haven't had a problem with run-on unless the diodes in the alternator were bad. Instead of a lamp, a DPDT (double throw, double pole) switch could be used to break the ignition and exciter line with seperate contacts.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
