Re: STIFF SHIFTING 400
Posted by Randy SE-MN. on March 09, 2005 at 05:26:56 from (206.9.216.59):
In Reply to: STIFF SHIFTING 400 posted by Redman Lee on March 08, 2005 at 15:09:48:
If it is sludge and crud buildup, I believe IH recommended that you drain out a gallon or two of the old gear lube and temporarily replace it with the same amount of kerosene, then drive it for a period of time. Then drain all and replace with fresh lube. With the shifter problem your experiencing, you should be able to feel any improvments as process happens.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
