Re: Governor setting on a Super A
Posted by Paul in Mich on March 09, 2005 at 13:05:37 from (64.12.117.13):
In Reply to: Re: Governor setting on a Super A posted by WOD on March 09, 2005 at 08:51:38:
WOD, The first thing I"d do is check the operating linkage to make sure nothing is binding or lost motion, and correct anything that would cause such a condition before doing anything to the governor assembly itself. Once that issue is solved or satisfied, and the problem you state still persists, consider the fact that the governor weights could either stuck into one position, or broken, since the fast idle shouldnt have changed once it had been set. Now then, if you have been into the governor and had it apart, then adjustments would be necessary. High idle speed adjustment is made with the speed change lever in wide open position by turning the adjusting screw which is located on the top of the governor housing.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
