Re: I'm Kinda Dense: Alternators Again
Posted by Bob M on March 09, 2005 at 13:26:12 from (151.190.254.108):
In Reply to: Re: I'm Kinda Dense: Alternators Again posted by Allan in NE on March 09, 2005 at 12:28:08:
>But, on an internally regulated alternator (I’m talking GM), the exciter circuit does not provide field current in any way whatsoever and the battery does not provide any field current to the alternator in any form.< Not quite! The exciter circuit uses battery current to provide the initial “flash” current to the field at startup. It draws this current until the alternator develops an output voltage higher than the battery voltage. >If this were the case, the darned alternator would stop charging if you removed the battery. It doesn't, take the battery out of the picture and the alternator just keeps right on a doin' it's job of maintaining system voltage and providing field current as needed.< Not recommended! The battery serves as a stabilizing ballast and helps the regulator system voltage under control. With the battery removed the system is liable to go unstable and either exhibit wild voltage swings (25 – 30 volts or more), or the alternator may simply self-destruct. Don’t ask how I might know this! >The exciter current only turns on the regulator gate and takes the alternator out of isolation. Yes, by hot-wiring the exciter, the regulator stays on all the time, but so what? There is always power at the light switch too. Since the regulator uses the alternator's own induced voltage as a field voltage source, without rotor rotation, there is absolutely no draw thru the field circuitry anyway.< Again, not quite. If the rotor stops, the regulator draws a couple hundred milliamps from the #1 terminal as it attempts to reflash the field. It will continue to draw this current until the alternator resumes generating current. If you run the alternator daily it won’t be a problem. But if left idle for several days the constant small drain will kill the battery. Thus you must have a switch to cut off voltage to the #1 terminal when shut down. Hope this makes sense! Bob M
Home
| Forums
Today's Featured Article -
Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
