Farmall H TracTracTor Re-Assembled!
Posted by Stephen McCoy on April 05, 2009 at 11:08:58 from (63.26.228.170):
Finally got my Farmall H tracked conversion put back together after a long winter. I replaced the original T-20 tracks with newer (and much better) tracks from a TD-6 and rebuilt both front idler wheel spindles with new bearings. I had a heck of a time getting the front idlers re-adjusted for the new tracks. They had been turned way out to take up the slack in the worn T-20 tracks, but after a broken pipe wrench and several bent "cheater" bars I got the "new" tracks on. The TD-6 tracks had 32 plates per side where the T-20 only had 29. I had the local Cat dealer remove the three unnecessary plates and links. I didn"t receive the mater pins with the tracks so I machined my own from two of the spare pins. My next step is having my students cut down each plate from 16" to 12". Its takes about 15 minutes to cut each plate (6 to 7 minutes per side). I figure if we can get 8 finished each day it will take about 10 days to get them all cut to size. I"ll get the all the "new" stuff primed and painted after that and re-attach the plastic pads to each plate. Enjoy the picture I took when I got finished a few weeks ago and the picture of the custom decals my students and I made.
