Re: farmall 706 310d smoking
Posted by MN Scott on March 09, 2005 at 20:33:34 from (206.9.216.65):
In Reply to: Re: farmall 706 310d smoking posted by trent on March 09, 2005 at 19:33:20:
Check the static timing of your pump. If thats set right the pump may need a trip to the repair shop to. Stands to reason if the injectors were bad the pump might be to. I just bought a 756 with the 310 that smokes and starts hard so I'am going thru the same learning curve you are. Mine has a M&W turbo kit that makes matters worse as the pump is turned up to provide more fuel to go with the extra air. BTW does anyone know what company supplys the higher compression pistons for the germans? I have not been able to find them in any catalog.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
