farmall cub charging woes
Posted by glenn at the farm on March 10, 2005 at 19:22:06 from (24.15.63.64):
I have a 1951 farmall cub with a 6v pos ground charging system, voltage regulator, not a cut out relay. the generator was just rebuilt and the regulator tested, it bench tested fine, i installed everything, polarized the regulator, and started the tractor, it charged intermittently then quit. if i jump the field on the regulator to the battery positive (positive ground) it charges. is the regulator bad ? the wiring all seems good.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
