Re: farmall cub charging woes
Posted by captaink on March 11, 2005 at 08:41:33 from (66.115.214.56):
In Reply to: farmall cub charging woes posted by glenn at the farm on March 10, 2005 at 19:22:06:
I have seen where the regulator will develop a bad ground connection. Try grounding it using a jumper from the positive side of the battery (or ground) to the regulator body somewhere. If it starts charging, look for rust etc between the regulator mount and where it mounts to. If it doesn’t charge with the jumper on, then the regulator is bad.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
