Re: Has anyone ever....
Posted by Bob M on March 11, 2005 at 07:46:20 from (151.190.254.108):
In Reply to: Has anyone ever.... posted by SuperCmore on March 11, 2005 at 06:14:46:
Reshaping the dubbed off teeth may or may not help. I found a new bendix mating to an old worn ring gear actually jammed more frequently than the worn bendix did. Also you’ll find the ring gear teeth are hard as an IRS auditor’s heart. You’ll probably need a small die grinder to take any metal off – a file may not touch it. Better approach is to either reverse the worn gear or install a new one (about $35). Once the tractor is split the gear is easy to remove. Warm it up evenly with a torch - doesn’t need to be terribly hot - and it will tap right off. To reinstall warm the gear up to 400 deg or so in the oven (do this on “girl’s night out” if you are married...). The hot gear will slip right onto the flywheel – no tapping required. Incidentally the starter pinion should be engaging the full width of the ring gear teeth. It may look however like it’s only engaging the 1/2” or so closest to the starter, since most of the wear occurs as the pinion is driven violently into the gear by the action of the bendix.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
