Re: LEAKING FLUID
Posted by Dave in CT on March 12, 2005 at 02:03:23 from (64.252.222.16):
In Reply to: LEAKING FLUID posted by FRANK on March 11, 2005 at 18:57:09:
There's a seal around the drive coupling, a gasket between the pump and the reservoir back plate, a gasket between the reservoir back plate and reservoir body and pipes screwed into the pump. Remove the inspection plate under the pump and, after cleaning things up a bit, you may be able to see where the leak is coming from. If you're lucky, it may be from where the pipes screw into the pump. If this is the case you can unscrew them without removing the pump and try putting some pipe-joint compound on the threads. Leaks anywhere else mean you'll have to drop the pump. Check the archives for methods on lowering the pump and rebuild tips. If you're going to replace the seal around the drive coupling, check out the method where you leave some oil in the reservoir and back off the coupling with a pneumatic drive - the oil provides the resistance you'll need to get it off. It's a lot easier (less prone to breakage) on the coupling and gear teeth.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
