Re: I-6 Rear rims
Posted by Haas on March 14, 2005 at 19:02:38 from (12.65.12.122):
In Reply to: Re: I-6 Rear rims posted by John M on March 14, 2005 at 15:12:07:
I suspect that getting the hub off the axle will be about as big a chore. The side I am working on did not even have the bolt and washer on the end of the axle when I got it. Nothing holding the hub on and no sign whatever of any movement. Also, that hub is one solid disk of cast iron. The hub alone without the tire and rim must weigh at least 300 lbs. It's 3 inches thick. I have the lift to handle it, but I think I'll give it some time. The brakes on the tractor are working, but there is no adjustment left and the brake lock is to the last notch.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
