Farmall Tractors Discussion Board
Re: Re: stroker kit for an M
Posted by jakee on December 04, 1999 at 20:31:03 from (152.163.213.73):
In Reply to: Re: stroker kit for an M posted by Tractor Guru on December 04, 1999 at 17:49:41:
the old M and W are all most a drop in.the edge of the oil pump need,s to be trimed and the cam turned down between the lob,s if you do the carb right and build a blue printed motor wit the good lp head you can expect around 90 hp,have 2 of them i built and there 4 years old on the pulling cicuit and no problems.
Post A Followup
: Re: Re: Re: stroker kit for an M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
