Farmall Tractors Discussion Board
Re: stroker kit for an M
Posted by Tractor Guru on December 04, 1999 at 17:49:41 from (192.156.19.50):
In Reply to: stroker kit for an M posted by Ben on December 03, 1999 at 08:24:20:
A stroker kit would works well in either engine. My choice would be the Super M (and I'm the Tractor Guru).
Post A Followup
: Re: Re: stroker kit for an M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
