Re: MD gas tank removal--steering shaft off first?
Posted by Bob M on March 17, 2005 at 10:18:07 from (151.190.254.108):
In Reply to: MD gas tank removal--steering shaft off first?? posted by novice on March 17, 2005 at 08:14:20:
On a gas M, if you unbolt the steering wheel stanchion at the tranny deck (3 bolts) you can swing the steering wheel/steering shaft/stanchion assembly upward. (The steering shaft will swing about the U-joint at the forward end of the tank.) This will give sufficient clearance to remove the tank without having to remove the steering shaft.
I'm not familiar with the throttle linkage on the MD - you may have to disconnect or remove it in order to do this.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
