Re: posituve or negitive
Posted by El Toro on March 17, 2005 at 10:25:15 from (205.188.117.73):
In Reply to: posituve or negitive posted by Donna on March 17, 2005 at 09:24:59:
Is there a ballast resistor installed in that ignition circuit? They're used to drop the voltage. I do not think the negative ground would cause the condenser failure. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
