Re: Tap Drill Sizes
Posted by greywynd on March 18, 2005 at 00:13:01 from (216.209.119.152):
In Reply to: Taps/Easy outs posted by greywynd on March 17, 2005 at 09:42:40:
When I started this post, I was thinking more about the easy out/broken bolt/tap subject from a day or 2 ago. Seems like I started something, and there's a bit more I felt I should add, especially for those of you learning about this stuff from the basics. When you go to drill a hole that you want to thread, there is a specific size of drill required depending on the thread size (diameter) and pitch (TPI, or threads per inch on standard imperial threads). I'm sure that most of you have done a bit of wrenching on the tractor, or car, or whatever, and have realized that most bolt sizes can be either a fine, or coarse thread. The tap drill sizes for those 2 taps WILL be a different size. There is a whole bunch of math you can do to figure out the size, but, the easiest way is to look it up in a tap drill chart. If you go to an industrial supplier, they often have these charts available for you, often free. Get one, and make use of it. I also found a good one on the net, the link is below. If you only have a basic set of drills, here's another bit of advice....when you go to buy a tap of a certain size, buy a couple of the right size drills for that tap, and keep them all together. That way you won't have to look it up each time, and they be together when you need them. Another thing that I would recommend that you guys get, is a variety of 'centre drills'. These are little short stubby drills with a small pilot on them, and they are designed to start a hole for the drill to follow. Tired of having a drill wander around when you go to drill a hole? Centre punch it, then use a centre drill to get started. They are strong enough that they won't generally break if you put some sideways pressure on it to get a hole started where you want it. Mark
Home
| Forums
Today's Featured Article -
Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
