Re: how much Kroil
Posted by Andy Martin on March 18, 2005 at 05:04:43 from (64.219.39.195):
In Reply to: Re: how much Kroil posted by PAULIH300 on March 17, 2005 at 17:34:55:
The use of too much force will break rings and cause a lot of oil burning.
I have freed up old tractors, some of which did not subsequently burn oil. It depends on how badly stuck they are. The exhaust open to rain for five years, you might as well tear it down. You may even have a freeze crack in No. 2. Sealed up but stuck after several years, if you can get it freed up without breaking anything you have a good chance at not having to tear down.
You can tell a lot by looking at the spark plugs when you pull them. If they look like it may run with the old plugs, that is good news.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
