Re: IH 656D - TA issues cont.
Posted by captaink on March 18, 2005 at 06:31:19 from (64.33.250.37):
In Reply to: IH 656D - TA issues cont. posted by Tip on March 17, 2005 at 13:43:58:
Let’s take this one step at a time… Based on your statement that the TA is properly adjusted, with the cover off, can you see if the direct drive clutch on the front of the planetary is disengaging? If so, I think that with the transmission in neutral you should be able to rotate the planetary in one direction with slight pressure on a pry bar. If you can, then you know that the direct clutch is releasing, therefore the TA should function (planetary and sun gears doing the gear reduction) or the tractor should stop (over-running clutch slipping). Because you say the tractor free wheels, I’m going to guess that this clutch is releasing. That leaves the planetary carrier as the culprit. I agree that as you suspect, a gear or gears are locked up preventing the gear reduction from happening. There may be something jamming the gears, or a failed gear or bearing preventing the planetary gears from rotating as they should. Good luck, sounds like you will probably be splitting the old girl and doing some TA work. My 2 cents…
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
