Completly stumped
Posted by Dixieland on March 18, 2005 at 15:07:25 from (69.179.198.176):
I installed my Farmall B starter and just as soon as it engages it hits a stump er something! I used my hand crank and turned the engine over several revolutions and tried the starter again. Still stuck. Removed the starter, checked everthing including the measurements to the flywheel. Put it back on and it hit a stump again. I tried 3 different starters and all three stops dead as soon as it engages the flywheel. Each time I checked it with the hand crank and have no problem turning engine over with it. I reached into the inspection hole and turned the flywheel with a pry bar and it turns easy. Why is this dadgum starter hanging up? Has anyone got any ideas what to look for? One other question. The double dots on the govenor gear matches with the double dots on the cam gears, correct?
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
