Re: Cmore Hydraulic Woes
Posted by CNKS on March 19, 2005 at 09:58:23 from (204.249.178.138):
In Reply to: Cmore Hydraulic Woes posted by SuperCmore on March 19, 2005 at 07:38:08:
If it's leaking that much, don't run it. Depending on which pump you have, it has either an o-ring or a regular seal. It is likely that the shaft has a groove, meaning that it might still leak after installing a new seal. Thus the Speedy- or Redi-sleeve. If the pump has a seal, installation of the sleeve is simple. If it has an o-ring, you have to enlarge the hole the shaft goes through to allow room for the sleeve-preferably by a machine shop. I assume you have a parts manual--Order the appropriate kit for your pump. There is more than one, and you will need to know which pump you have before you order. When I rebuilt mine about 3 years ago, CIH still sold the kits, if not you will have to get the separate parts. Mainly that includes the gasket you mentioned and two other o-rings that fit where the lines attach to the pump, along with some other miscellaneous parts.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
