Re: 300 Utility Carb Rebuild
Posted by Ron Smith on March 19, 2005 at 18:25:04 from (205.188.117.73):
In Reply to: Re: 300 Utility Carb Rebuild posted by PAULIH300 on March 19, 2005 at 17:29:37:
Thanks for the pointers. It seems like all of the passageways are clear. I just came in from messing with it. I'll dink with the float tomorrow. I wonder how high the float level should be? I think it is flooding. This tractor, if you take the idle mixture screw out all together, it runs better. It gets more air. The other problem is that the adjustment needle really doesn't seem to do much at all. It runs about the same no matter where it is adjusted. I need to be able to reduce the fuel in the mixture that is for sure. I think they make some gasket maker that will hold up to gas and oil...possibly the black stuff will. You might just want to press a piece of paper on it and cut out a thick gasket from gasket paper using an exacto knife. I see what you mean about the throttle shaft lining up.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
